Winter Storage
Old 09-02-2011, 08:13 PM
Potato_Potato's Avatar
Potato_Potato
Potato_Potato is offline
Originally Posted by rwtrick
Unfortunately, it's getting close to the time when I'll be putting my bike away for the winter. It will be stored in a climate controlled place - my question is after I fill my tank should I add stable to the fuel?
I know some people do and some don't - what's the best course of action? This is my first time storing a bike for the winter so I have no personal experience to draw from.
When you add the stabilizer be sure to run it long enough that the stabilized fuel enters the fuel lines and intake.
Here is what I do;
Winterizing
Change all fluids & oil filter
Store battery inside on a Battery Tender
Top off fuel (It's amazing how much more fuel you can add with the bike straight up and using a fuel can.), stabilize fuel tank and fuel system by running the stabilized fuel through the motor, fog the intake until the motor stalls, and fog tank - if storing inside - drain and fog tank
Clean & oil air filter
Remove spark plugs, clean, inspect (replace if necessary) and check gap
fog cylinders, apply anti-sieze replace plugs
Fog mufflers
Inspect and service (clean) brake calipers and pads, bleed / change brake fluid
Put bike on lift (if no lift over inflate tires by a few #s)
Wash, wax & detail
Cover with breathable cover and hang a Goldenrod or lightbulb to the frame
Spring wake up
Check tires for cracking, air pressure
Check operation of lights, signals, brakes & brake lights, horn
Take bike off of lift (fuel may come out of the overflow so go for a ride right away!)
After the first short ride check fluid levels of crank, tranny & primary
Old 09-02-2011, 08:29 PM
ChristoHD's Avatar
ChristoHD
ChristoHD is offline
Thumbs down No, no, no, say it aint true, SAY IT AINT TRUE!
Originally Posted by Rockhanger
Sta-bil , Battery tender & cardboard under the tires has worked for me for years.
Ditto.
I also start her up every two-three weeks, let her run for 15 mins.
OMG...What the heck am I doing answering this thread! I am NOT ready for this, not one bit! OP should be tarred and feathered for even mentioning this unmentionable! LOL
Old 09-02-2011, 09:50 PM
cripula's Avatar
cripula
cripula is offline
What's a Goldenrod?
Old 09-02-2011, 09:52 PM
parabellum_9x19's Avatar
parabellum_9x19
parabellum_9x19 is offline
Originally Posted by cripula
What's a Goldenrod?
Its an electric de-humidifier designed for gun safes or small closets.
Basically its just a very gentle heater that can't set anything on fire, which banishes humidity from small spaces.
Old 09-02-2011, 09:55 PM
mi2az's Avatar
mi2az
mi2az is offline
you also need to run the motor to move the fuel with stabilizer in the system
All I can say is I am gald to be in Phoenix AZ
Old 09-02-2011, 10:03 PM
Potato_Potato
What's a Goldenrod?
Used sometimes to reduce moisture in a stored motorhome, boat or other small area. Its really just a rod that stays warm to evaporate moisture. I use a work light and hang it from the frame as it doubles as a nightlight / security light.
GoldenRod Dehumidifier
Old 09-02-2011, 10:04 PM
cripula's Avatar
cripula
cripula is offline
Thank you! Found their website, it looks like just what I need for the unheated shed my FLHT lives in.
Old 09-02-2011, 10:05 PM
BackRoader's Avatar
BackRoader
BackRoader is offline
Grab your ba!!s and ride it year round. No need to winterize!
Old 09-02-2011, 10:59 PM
baust55's Avatar
baust55
baust55 is offline
Fog ? What is fogging?
Old 09-02-2011, 11:08 PM
Potato_Potato
Engine Fogging Oil
Quick Reply: Winter Storage
