Ok guy's godda pick yur brains on this crazy issue i'm having..
Ok not sure how many were following my broken cam issue but here the deal, Had bad noise in motor and was a a stop light going onto a bridge back to Missouri and half was across bike quit, long story short the from cam sprocket was cracked and spun on shaft, ok put se 255 cams in as well as se adjustable pushrods, bike started fine sounded fine and when it warmed up hammering noise back, shut sown and found exhaust lifter on fron cyl and intake cyl on rear I could collapse with my finger the other two was fine, so kinda what happened chicken or egg deal, Does any body have any idy what is going on with my motor? It's an 08 street glide with only 12,000 miles, gunna put lifters in tomorrow. Here's is what I found with the front cyl. cam.. could really use some experience here, got dealer and all local indy's stumped on cam..
Thanks man..
Looked in the cylinder with a snapon scope and did not see any signs of that. when the cam spun did not hear any metalic bang, just shut down, the sprocket spun on cam not allowing it to open any valve.. Did not even sound like it jumped time it was that quick.
you have oil pressure? have you looked at the oil pump? , I would check the runout on that crank too, have a feeling things run out of oil as soon as it gets thinner due to warming up. what about the inner brgs, I don't see any scoring on the brg surface , but something stopped that cam from turning and the chain kept right on turning!
