tbw replaced, bike wont startbut at full throttle.
tbw replaced, bike wont start but at full throttle.
I replaced my bars on a 2010 fltrx and ran the wires internally. With this i replaced the tbw with the screaming eagle one (the one with no green plug) to make pulling the wires easier and cuz of the horror storie ive heard about the green plug coming apart. I put everything back together and when i go to start the bike it wont start. I tried this multiple times with no luck. I then tried to start it again with the throttle cracked and the bike fired up but even when i let go of the throttle it seemed to go to full throttle. I shut it off before i let it go any farther. any advice??
When you buy the TBW with the long wires they are threaded down the handlebars and once they come out the hole in the middle of the bar you have to plug all the individual wires into the Molex connector. Are you SURE you plugged all the wires in the right holes? Easy to get one out of place.
Hi there
I changed my bars out and extended the TBW wires. I also removed the green connector. I had no problems with the install except when I started I had no throttle at all but it would idle fine. Stepped back and a thought occurred, plug the harness back in. Had moved them out of the way and missed it when I plugged everything back together.
I would suggest re-looking your wiring and ensure that all pins are input in correct pin holes on molex connector. There are two set of wires three each that are the same color code. These are ran in two different colors of heat shrink from the throttle end. Ensure all are matched correctly and this should fix your problem It sounds like they may be reversed. If need be I can find my notes from when I took apart.
Good luck, TJH
Good luck, TJH
Tjh-flhtk2012
Thanks for the reply. It gives me the idea of trying to start it without the harness plugged in to see if it starts at an idle. That would indicate a problem with TBW wiring or throttle twist grip device. I have the green plug wiring diagram and believe I have followed it exactly. I wonder if one of my solder joints came loose? Thanks again
For reference here's correct wiring for cutting out green plug.
HD has split the wires coming from the sensor into two group with two different color shrink wraps:Black and Yellow. I will now refer to these as Black side wires and yellow side wires. Each side has a white wire, black wire, and red wire. This is what it looks like:
Here is how the wires will hook up.
Blue Wire------(Black Side) White Wire
Brown Wire----(Black Side) Red Wire
Black Wire-----(Black Side) Black Wire
Grey Wire-----(Yellow Side) Black Wire
Red Wire------(Yellow Side) Red Wire
Purple Wire----(Yellow Side) White Wire
