Thump going into 1st gear??
I have a new Limited, 1700 miles so far. I did the 1000 mile service including the clutch adjustment. Before and after the adjustment I have a loud thump when going into first. I went with Mobil 20-50 synthetic V Twin oil in the primary. The clutch feels correct and the fluid level is right on, checked twice.
Is this normal, everything looks and feels good when riding except for the thump into 1st.
I had this on my Honda and got used to it, but worried about the Harley. Any suggestions from the experts here??
I have also read and learned alot reading all the threads on this great forum.
What is the loud bang some people hear when they start up and their compensator needs to be replaced? Is that when they go into 1st gear?
Heck, even my Buell had it.
I think its just part of the design of the harley transmissions.
(My Yamaha warrior and my FZ6 also had the same thing, regardless of what fluid I ran)
If you do take it to the dealer, ask them to inspect the primary chain for correct tension, if that is out of whack, it can give things a clunky feeling.
That loud thump is normal.
Sometimes mine feels like it would just take off down the street, even though the clutch is dis-engaged.
However, there have been times, when the shift to first has been silky smooth and quiet.
I have no idea why it's sometimes a loud bang and sometimes a smooth quiet shift
I've tried every possible method of shifting from:
Cut throttle as you pull in clutch, immediately shift.
Cut throttle, pause a moment, pull in clutch, immediately shift.
Cut throttle as you pull in clutch, delay shift.
Cut throttle, pause a moment, pull in clutch, delay shift.
All four methods will produce varying results depending on the speed, rpm, position of the stars, and what's currently on my tivo.
