will a 2008 flhx rear fender fit directly on to a 2005 flhtc
There are two harnesses. One is for the tail light and turn signals; and, the other is for the fascia LED. The tail light/turn signal harness is the same--just unplug the OEM connector it under the seat and connect the one with the fender.
The fascia LED harness uses the tour pak light harness that you are currently using for your tour pak lights. You can make a pigtail so that the tour pak lights and fascia LED use the tour pak harness; or, use the upper left socket in the circuit board behind the tail light lens; or, use the accessory connector under the seat. Using the upper left chamber behind the tail light will be easy if you are reusing your pancake turn signals since it's currently used for the fender tip light. You can simply reuse the connector from the fender tip light to replace the connector on the fascia LED harness.
If you're using the SG turn signal bar, that chamber is used by the license plate LED's in the bar, and you can splice the LED wires to the license plate LED wires.
Good luck with your project.
Carl
Carl
army_sarge
03-22-2010 02:15 PM
07blackcherryflhx
05-24-2008 11:46 AM
