TBW Plugs
TBW Plugs
In this pic there are two plugs on my TBW sensor,the green plug,and the little black plug. On my 08 there was no little black plug,the wire was just snipped off and heat shrinked,it did not go anywhere. Now there is a little black plug that seems to go all the way into the fairing,but it is not being used. Can anyone tell me what this is for ? I am going to do away with it if it is not needed,fo I will have more room to internally wire my new bars.
The heat shrink on is for the optional heated grip option. If you are going with aftermarket bars and routing your control wires through the handlebars you may want to think about deleting the green plug and hard wiring the 6 wires that control the TBW for two reasons:
1) make more room
2) eliminate a point of failure in the TBW wiring harness.
Just my 2 cents
1) make more room
Just my 2 cents
Has anyone ever extended the TBW wires so as to move the green plug out of the inside of the bars and into the fairing? If so what gage wire is it,and is it single or stranded wire inside the red,black,and white wires on the TBW Assy.? Any info on internal wiring on bars would really be helpful. I have done this once before but this time I want to make it easyer by relocating the green plug out of the inside of the bars,and by removing the outer black insulation from the wire looms as well. This way I would have more room inside the bars for the wires. Whatever info you guys can give me would really help.
Thanks for the info TexVet and Dawg. I just went ahead and made my own long wire sensor by cutting the wires between the sensor and the green plug and adding 30" of wire so that now the green plug will be pulled all the way through the bars and get plugged in inside the fairing,and since I'm not a fan of heated grips I just clipped that wire so it looks like the old one out of my 2008 Road Glide. Thanks for all the info guys. If this works I will be very happy.
1) make more room
Just my 2 cents
1) make more room
Just my 2 cents
Thank you!!
jamminjimmi
08-28-2011 11:14 AM
sixshooter
01-30-2011 07:56 PM
