Power Commander 3 or 5
the reason Dynajet said the 3 is because the 5 plug won't fit the 08. Fuel Moto puts a new plug on the 5 and sells it at the same price as the the ones for the 09 up which it designed for the PCV I have the PCV on my bike 2010 FLHTK and friend has one for 2008 Ultra Classic and it works same as mine. Get it from FuelMoto and save money also and get a map already installed. It takes 10 minutes to install and you are good to go.
Trust Fuel Moto, they will give you the tech support that you need and double the warranty.
The advantages of the PC V over the III are auto tune capability, smaller size and I believe it has more parameters that it can work with, Id definatly go with the PC V if your going to use a piggy back tuner.
IMO the best bet out there for ease of use and most extensive tunability is the Power Vision. I just started to use one last week and its great, bike runs better than it did with the PC V and I dont have anything under the seat.
I had the PCV on my 2008 and it worked great. Since then I have gone with the Power Vision which is also a great tuner. The PV gives you more control over the settings in the entire map. Definitely go with the PCV over the PCIII and if you want even more flexibility, I recommend the Power Vision. Both the PCV and the PV have the ability to use DynoJet's autotune modules.
Anyway, I had a PCIII for about two years until the PCV came out, and didn't hestiate to buy the new model. It was a good move for me to change, but if I was starting from scratch and had a choice I would definitely pick the PCV, as unless you want a plug-and-play device and have no plans to do more advanced tweaking or add Auto-Tune it is worth the ~$30 (or whatever) extra. OTOH if you want to just plug it in and go with no aspirations of doing any further tweaking, the Fuel Moto tuner (PCIII without exterior buttons) is the best bang-for-the-buck option, IMO.
