Want to change headers
Yes that right. Want to change my flhx 2011 header. Instead of removing
the cat, thinking of using an other header from an other year bike thats
fit.even putting the senors back on the pipes.....sooo,, which flhx headers
from what year can i use ..and will i be able to use my sensors...
Bye bye heat..and a bit more sound... Thanks again..
CA bikes have cats from 09, 49 state 2010
different size o2 sensors if you get an 09 header...
nightrider.com sells bung adapters or you can take the new header to a muffler shop and they can weld in...
or
easiest way, all around- remove your cat from your header.
You aready own it, and any other way is going to cost you one way or another
Mike
or
Mike
Vivid Glide 103
06-22-2011 04:33 PM
