Hard to find neutral after SE Comp install
Old 09-01-2011 | 10:24 PM
iclick's Avatar
iclick
Originally Posted by V2Evo96
Oh no worries iclick-- I didn't take it the wrong way which is why I put in a "big grin".
That's good and I did see you grinning from afar. Honestly, I wish mine would go into neutral from 2nd, as that would be very convenient at times. I'm going to ask around locally and see if any others have experienced this.
Old 09-02-2011 | 01:01 AM
V2Evo96's Avatar
V2Evo96
Well by way of follow up I have just checked the section for shifting control in my operators booklet and while there is a reference to neutral from 1st, there is no reference to reach N fron 2nd....
I'm curious as it may be a situation of "some do, some don't". I checked my shift pattern again on the way home from work and it does indeed engage N from 2nd very easily and I can feel the detent coming down from 2nd.
Good on you for asking around-- I'll do the same when I next ride with others.
Old 09-02-2011 | 02:57 AM
smithbrl's Avatar
smithbrl
Regarding your comment about sometimes missing N from 1st, if your chain was replaced recently it once it beds in a bit it could improve, but I reckon a clutch adjustment will help.
I would make sure the Primary case fill level is correct as well-- as it can make a difference to the way the clutch engagement/drag feels. JMO
I figured a break in period for the chain would be necessary. The primary appeared to be overfilled so I drained and replaced with the recommended amount. This helped some but the problem is still there for now. Before I replaced the primary fluid, it was really hard to find neutral. Most of the time it shifts fine but sometimes I go back and forth from 1st to 2nd then back from 2nd to 1st....Thanks
TriGeezer
04-21-2016 12:08 PM
sn95bullitt
08-27-2015 06:48 PM
monster715
04-10-2014 09:00 AM
Velocity1
07-28-2013 08:35 AM
fettnersa
11-02-2010 01:15 AM
Quick Reply: Hard to find neutral after SE Comp install
