Progressive Front lowered SG Opinion
Old 08-29-2011 | 05:45 PM
sfetty's Avatar
sfetty
Default Progressive Front lowered SG Opinion
Don't know how many of you guys have lowered your Street Glides, but I had mine done with Progresive Drop ins. It was supposed to be lowered 1 inch. To me it feels like it went down way more than that. You can see from the picture comparison a significant difference.
If you look in the pictures you can see how far down the bottom of the upper is on the fender. Does anybody else think this is lower than 1 inch? I absolutley had to go with a 1 inch shorter Arlen Ness kickstand. It still sits up pretty straight in my opinion. Not sure if the installer missed the spacers (if there were any) or if this is the way everybody elses is??
Attached Thumbnails Progressive Front lowered SG Opinion-flhx-low-side.jpg   Progressive Front lowered SG Opinion-016.jpg
Old 08-29-2011 | 05:51 PM
buggy's Avatar
buggy
Its gona look like its lower b-cuz it is ! the rear is only 3/4 in lower. you really only need 1" if your runnin a 21" wheel.
Old 08-29-2011 | 05:58 PM
Mouse in my cup's Avatar
Mouse in my cup
I put that kit in my ultra, the amount of drop depends on what you cut the pvc spacer to. You should ask the installer what length the spacer is, then you can look on the chart from progressive and find how much it was dropped. For the kick stand I went with a wedge and substituted the bolts in the kit for bolts I knew were grade 8. Hope I helped.
Old 08-29-2011 | 09:05 PM
sfetty's Avatar
sfetty
Mouse in my cup:
Does your bike lean on the kickstand much? That is my biggest problem. The 1 inch drop made it stand up enough that a good wind would have blown it over. Now with a shortened stand it is barely good enough. If I turn the wheel to the right of center at all, the kickstand will push the bike over (had to catch it twicw now while working on it). I do drag the kicstand occasionally also when I turn hard to the left.
The mechanic said he was almost sure he put the spacer in it. Does you bike look similar in fender clearance to mine?
Old 08-29-2011 | 09:10 PM
Mouse in my cup
Yup lean is good, sounds like better than yours. Only way it will fall is if the stand breaks. I will take a pic tomorrow.
Old 08-30-2011 | 12:01 AM
sublime_ac's Avatar
sublime_ac
My sig pic is with the racetech one inch lowered springs / cartridge emulators...
Old 08-30-2011 | 08:58 PM
sfetty's Avatar
sfetty
Thanks for the responses. Nobody else including the technician form Progressive that I talked to have had this much trouble with kickstand length. I think I am going to attempt to pull the tube caps and check the spacer length, if there is one in the bike at all.
Old 09-01-2011 | 08:51 AM
Mouse in my cup
Sorry this took so long, I have been crazy busy. The wedge I used was p/n 48-2763. This is with the Progressive drop in fork kit and 1 inch shorter progressive 440 shocks.
Attached Thumbnails Progressive Front lowered SG Opinion-img_20110830_145600.jpg   Progressive Front lowered SG Opinion-img_20110830_145611.jpg   Progressive Front lowered SG Opinion-img_20110830_145621.jpg   Progressive Front lowered SG Opinion-img_20110830_145637.jpg
Old 09-01-2011 | 09:00 AM
Mouse in my cup
http://www.progressivesuspension.com...-in%20Inst.pdf
These are what came with mine. I think the chart is for a 1" drop, but you will have to call to verify. I didn't see instructions for the newer bike on the site, they may be the same instructions.
Old 09-01-2011 | 09:39 AM
RaceFace's Avatar
RaceFace
Your bike looks good! How does it ride??
