Hoist to lift your bike?
I had a rear flat last year (maybe year before) and managed to get my bike to a metric dealer to have a new tube put in. Any case they used a hoist to lift the bike and I thought it was a pretty cool idea. I have a very large steel building and pretty certain the structure would support the weight. Your thoughts on a hoist?
If you mean a "chain- motor", 1/4 ton motors are cheap and run on 110, they are reversible ( I don't think 1/2 ton motors are available and 1 and 2 ton motors require 2 phase power, are heavy and costly---1/4 ton may do fine on a static load)
add a 'span-set" strap and you can lift your bike, pull motors from cars etc.
1.) no guess work, you want an engineer to determine the static weight load your roof system can support, than calculate dynamics, such as wind, rain, snow etc.
2.) Grainger has 'em or you can contact any local vendor who supplies concert lighting or sound systems.
They can also suggest personnel to sort you out.--- you do want the motor at the load end and the chain attached above, easier to install, and for servicing the motor should it need.
3.) a hanging balanced load ( and a bike on a sears, harbor freight, sams club or J&S lift) will change center rapidly when a wheel is pulled off.
My Pal forgot that, dropped his rear wheel ( to change shocks) and the bike nose dived, pulling the strapped to it lift with it
so probably not the best way.
A lift table with a drop out rear tire section would be the way--- and less expensive
mike
mike
A friend with an after market shop uses a hand operated chain fall when he's only working on one end of a bike. He uses soft ties at the bike, & tie down straps from the hook to the soft ties. Works great lifting one end, but if you lift the entire bike it tends to swing. For that he just uses normal table lifts.
