Motorcycle lifts
Old 08-27-2011, 07:52 PM
brunosrk's Avatar
brunosrk
brunosrk is offline
Don't know about fitting under your bike, but I've had my J&S jack for 6 or 7 years now and it works great with no problems what-so-ever. It fits under my 02 Road King if that's any help.
Old 08-27-2011, 07:59 PM
usmc3468's Avatar
usmc3468
usmc3468 is offline
Also if you are gonna bit the bullet and get either a J & S or pitbull, the only thing that sets them apart is that the pitbull can spin 360 with the bike on it and I didnt know that until I bought my J & S. I would have bought the pitbull if I would have known......
Old 08-27-2011, 08:23 PM
SteveO's Avatar
SteveO
SteveO is offline
The only quality, heavy duty and safe jack is the J&S.
Old 08-27-2011, 10:15 PM
dfndr's Avatar
dfndr
dfndr is offline
My Pitbull air operated lift with swivel table is great. No pumping with your foot forever and swivel table let's you easily turn bike for best lighting as you work around bike.
Old 08-27-2011, 11:04 PM
cruzmisl's Avatar
cruzmisl
cruzmisl is offline
Originally Posted by usmc3468
J & S Jack Rocks....... You get what you pay for.
What he said. Really glad I bought a good jack. Worth every cent.
Old 08-27-2011, 11:26 PM
Matt0987's Avatar
Matt0987
Matt0987 is offline
I got a lift off Craigslist. I see them there regularly for $40 to $300. I do not know the brands. I got a lift for $75 bucks that is like new. It holds my RKC very stable. Easy to pump up with my foot.
Old 08-27-2011, 11:37 PM
turnerbend's Avatar
turnerbend
turnerbend is offline
Got the OTC 1545 lift for my 07 Ultra Classic for $149 on Amazon.com.
It is a low profile heavy duty jack that will slide right under my frame. It weight around 80 lbs.
Old 08-27-2011, 11:43 PM
Mike's Avatar
Mike
Mike is offline
Originally Posted by strtarrow
How much for that lift, where did you get it and can it be operated from a small (120 PSI) compressor?
You can check the pitbull website for the current prices.
I'm using a standard 30 gal, 5 hp 110V home type air compressor.
The biggest reason I went with pitbull instead of J&S was because of the higher lift on the pitbull. If you don't need that, you could probably save a little money with the J&S.
Old 08-28-2011, 12:12 AM
mjb765's Avatar
mjb765
mjb765 is offline
I have a Pitbull also--Love it. Had to decide between that and the J&S. Both good products, but the Pitbull lifts the bike higher.
Old 08-28-2011, 07:21 AM
Climb14er's Avatar
Climb14er
Climb14er is offline
Definitely! +1
Quick Reply: Motorcycle lifts
