Harley Bagger Audio Sys Amplifier Set-up
Old 08-27-2011 | 03:39 PM
JMJOHN's Avatar
JMJOHN
Platinum Sponsor
Default Harley Bagger Audio Sys Amplifier Set-up
The audio system listening environment on your Harley Bagger is quite different from your auto or home system.
When listening to music inside your home, apartment or automobile, you might crank the music up quite loud at times to enjoy your favorite sound tracks, but usually not too high, to a point that the music distorts, because unless you have had a “few too many”, the music just plain sounds BAD when turned up to high distortion levels.
Distortion is what damages a speaker, not necessarily high power levels. You can connect a speaker with a 50w max power rating to a 250w per channel amplifier, and if you don’t crank it up to high distortion levels, it will play just fine for many years.
Conversely, you can take a speaker rated at 250w max power and connect it to a 100w per channel amplifier, and if you crank it up to high distortion levels for hours on end, the speaker will be damaged or blown in a short amount of time.
On your Harley, when listening to music on the highway, especially at high speeds, it is impossible for most riders to be able to actually hear when the volume is cranked up too high, to a point where the music is distorting,,,, we just ride down the road happily listening to very loud distorted music, hour after hour and then wonder why in the hell our speakers and/or amplifier are damaged in a short amount of time.
This distorted listening scenario on your Harley would be equivalent to sitting down in your living room, turning on your 1000w Macintosh powered 5.1 Dolby digital surround sound system, with twin JBL towers, powered separate subwoofer, and cranking the volume to maximum on the dial, pushing all speakers way up to high distortion levels ,,,, then walking out of your house for a couple of hours, only to come back and see what is left of your audio system and speakers.
This is exactly what many of us are doing to our Harley Bagger audio systems.
THEN you have to go thru the hassle of taking your fairing off, diagnosing what is blown-up or damaged, getting replacement parts from the various manufacturers, (some under warranty, some not) reinstalling everything, only to go out and do the same thing all over again!
Now I think I am just like all of you ,,,, I want THE BEST possible performance out of my Harley Bagger audio system, period. I thoroughly enjoy my favorite music while I ride and if I want it loud, I want it loud, regardless of how fast or slow I am going.
To accomplish this without burning the system down every time you ride at high speeds, it is absolutely essential that the amplifier gain adjustments, on your high powered audio amplifier are properly set.
Use the guidelines below for the J&M Corporation brand high-powered amplifiers for the Harley Bagger audio systems. ((these guidelines may also apply to other brands of audio amplifiers used on your Harley))
You want to first adjust the amplifier gain controls to minimum, bass boost (if equipped) set to minimum, crossover switch to the FULL position.
Then slide a good commercially recorded CD into your radio, (Harley HK or automotive type replacement) and crank up the volume to maximum ,,,,, as far as it will go.
“IF” you get distortion on the song track BEFORE you are able to crank the handlebar volume to maximum, you will need obtain the correct HK-Radio-to-RCA jack, isolated input signal adapter from J&M before you can continue, so that you will have a useable range of control on the gain adjustments of the amplifier.
If you are using an automotive type replacement radio in your Harley, make sure that you are connected to the amplifier, using a direct RCA-to-RCA jack cable harness.
Then, with the handlebar volume adjusted to maximum, without hearing distortion, carefully adjust & increase the amplifier gain controls for each channel, to a point “right-before” distortion is heard, but not any further.
This way you will be able to crank the music volume all the way up to maximum on the highway if you want to, without worrying about damage to your speakers or amplifier.
With the amplifier gain controls adjusted in this manner, you will also be able to fully utilize the AVC control on the Harley HK radio.
I am available most days of the week, at John@Jmcorp.com if you need assistance/recommendations when building or tuning the audio system on your Harley Bagger.
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old 09-14-2011 | 11:21 PM
Bigrell's Avatar
Bigrell
Stage II
Really like the information, want a really good system just you talked about, thanks
Old 09-14-2011 | 11:27 PM
Mixter's Avatar
Mixter
Thanks John great info!
Old 09-15-2011 | 08:13 AM
hougz79's Avatar
hougz79
Thank you. Seems that the audio threads are really becoming a hot topic recently.
Old 09-15-2011 | 10:34 AM
Kesean's Avatar
Kesean
Good information
JMC22
Audio Systems
05-23-2015 08:06 PM
AmericanHB
Audio Systems
12-10-2014 10:12 PM
kryingame
Audio Systems
05-18-2014 09:30 PM
kryingame
Audio Systems
03-31-2013 01:59 AM
Mr Wonderful
05-27-2008 10:12 AM
Quick Reply: Harley Bagger Audio Sys Amplifier Set-up
