Looking for Low End Toque & Cooler Temp
Old 08-26-2011, 12:52 PM
Lone Rambler's Avatar
Lone Rambler
Lone Rambler is offline
Default Looking for Low End Toque & Cooler Temp
I have a 2012 Street Glide with the 103 of coarse, 75% of my riding is in the mountains back roads. Third & Fourth gears for miles at a time is not unusal for me. 2 up riding & I alone am pushing 280-285 the bike does fine with the 103 but I am looking to cool it down & gain a little more grunt on the bottom end. At these speeds 2up riding & baggs loaded down in hill country I want it to run as cool as I can get it too.
I am looking at running the V&H Power Duals, V&H Turndown Mufflers (removable baffles), SE-255 cam install, Stage 1 or 2 Arlen Ness Big Sucker Ac, or SE heavy breather, & installing a Tuner of coarse.
Any better ideals or advise is welcome. Help me out if ya can Thanks
Attached Thumbnails Looking for Low End Toque & Cooler Temp-10-pine-mt.ky..jpg
Old 08-26-2011, 01:16 PM
gasbrnr's Avatar
gasbrnr
gasbrnr is offline
I was going to go with VH until I heard about the scraping issues when cornering. I went with the Fuelmoto headpipe,SE air intake,PC PV and Jackpot 4" slash downs and it runs like a raped ape. I only have a 96" and don't think I'll need a cam. Give them a call first and see what they have for your 103".
Old 08-26-2011, 01:37 PM
tj316's Avatar
tj316
tj316 is offline
Cyclerama CR-575 Cams and a 2-1 head pipe will get you over 100 torque at 2500 rpm's and cool you down
Old 08-27-2011, 12:02 AM
Lone Rambler
Yes I should give them a call & get there opinion anyway, Thanks.
Old 08-27-2011, 12:16 AM
hockey8787's Avatar
hockey8787
hockey8787 is offline
The 255's will give you the low end grunt you are looking for!!
Old 08-27-2011, 12:20 AM
lh4x4's Avatar
lh4x4
lh4x4 is offline
Gutting the cat, adding the SE I air cleaner and a Fi2000R Cobra fuel programmer will cost you under $500 and will run the engine cooler and stronger than any other method.
I run three bikes that way. The 10 Ultra pulls the Rockies in 6th gear. Never any pinging and I run 87 to 89 octane. It went through Death Valley in the afternoon with no issues.
I run the stock exhaust.
The set up yields 50 mpg and the Ultra has 18K on it with that set up. Again spent less than $500.
The Cobra is plug and play. Only takes 30 minutes max to install. No need to dyno the bike.
Old 08-27-2011, 01:33 AM
arealinvestor's Avatar
arealinvestor
arealinvestor is offline
If your looking for a more tq I would run a good 2 into 1 exhaust, & a good cam to match.I don't really care for the SE255.They build alot of heat, & they need a good tune to help ease hot starts.I would go with a Woods high flow A/C kit,D&D Fatcat exhaust,Woods TW 5-6 or similiar grind,& a good dyno tune,with a TTS Mastertune or a SERT!!!
Old 08-27-2011, 06:55 AM
troop's Avatar
troop
troop is offline
Andrews 48H another cam to consider ...
Old 08-27-2011, 07:58 AM
itsaw0rkinpr0gre$$'s Avatar
itsaw0rkinpr0gre$$
itsaw0rkinpr0gre$$ is offline
"Seeker of Freedom"
I've heard the power duals hold a little more heat on the right side by your leg. You may want to consider a true dual header if heat is a concern.
Old 08-27-2011, 10:27 AM
kbktulsa's Avatar
kbktulsa
kbktulsa is offline
I have VH true duals, with rush slip ons, SE255 cams rev ems. and harley oil cooler, rode alot of miles this summer and it was over 100 outside. the bike oil stayed right at 237 on the hottest days. and never had any problem with hot starts. i am running a 96 inch not 103. Never had any problem with the VH dragingin the cornors.
Quick Reply: Looking for Low End Toque & Cooler Temp
Top
© 2024 MH Sub I, LLC dba Internet Brands
Follow Us
