Anticipated Break Pad Wear - Front and Rear
I ride a 2010 Limited. I just got back from the Americas 911 Ride and was checking out my bike, doing the 15,000 mile service items. Upon inspection of the rear pads, I estimate that I have about 40% of the rear pad left. I checked with the local dealer and was told that the pads appear to last longer than a rear tire, about 15,000 miles, but not as long as two tires. I would assume I will be changing the rear pads about 20,000 to 25,000 miles. How does this compare to what you are seeing. The front pads are hardly worn yet.
completely depends on the rider--- and type of riding--- you can ride 1000 hiway miles and only use the brake 4 times for fuel stops
some riders rely on the front brakes and use them so as to minimise overheating, fade and warping.
My Pal Rick uses his rear brake all the time, skids, warps, fades and pretty much doesn't have a clue... his pipes are also the loudest.
Aside from that he's a nice Guy
Mike
Mike
Mike
Mike
18k miles. His fronts are great. I have about the same miles with less than
50% wear.
