Anticipated Break Pad Wear - Front and Rear
You can make them last longer if you use them togeather, on a straight line stop from any speed apply the rear brake first then the front. your rear brake keeps the bike headed in a straight line but your front give you the most stopping power. Lyndall makes great replacement pads over the stock.
Like the others have suggested, depends greatly on the rider's braking methods.
I've ridden with guys that do full panic stops at every light...for some unknown reason, they burn up pads in a couple thousand miles.
So, that's why you do the little inspections every once in a while...when it's time to replace them, replace them. Should take about 15 minutes to replace the rears and a little more for the fronts.
I just replaced the stock pads at 15,000 miles.
Wanted to try the Lyndall Z+ pads front and rear , the stockers were noisy and dusty.
I'd say the rears would have gone 20-25,000 and the fronts maybe 18,000.
I'm a pretty conservative rider , so I usually get pretty good mileage from all my vehicle brakes.
I do like the Lyndalls , a bit smoother and quieter , plenty strong braking , nice feel also.
Mick
Mick
sundancewind
05-27-2011 06:16 PM
