Jiffy stand loose
Old 08-24-2011, 09:10 PM
beansSG's Avatar
beansSG
beansSG is offline
Default Jiffy stand loose
I just noticed that my jiffy when up seems looser then I remember. I just had the 1000 mi service done by the dealer last week. Does the get any attention during that? Just doesn't seem right.
Old 08-25-2011, 07:19 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
The Jiffy gets greased.
Maybe the spring is weak.
Medevack1 (09-28-2022)
Old 08-25-2011, 07:27 AM
Port Dawg's Avatar
Port Dawg
Port Dawg is offline
Supposed to get greased that is...mine was not.....I know easy fix but still....mine makes a pretty good noise while returning to the up position
Old 08-25-2011, 07:33 AM
1flhtk4me's Avatar
1flhtk4me
Place your bike on a lift or have someone sit on it.
Get some wheelbearing grease(something thick)and use a small acid brush or something to get the grease into the housing while rotating the stand so the lock tab moves back and forth.
Old 08-25-2011, 07:34 AM
1flhtk4me's Avatar
1flhtk4me
Sometimes the spring will be causing the noise.
Old 08-25-2011, 07:51 AM
DPete's Avatar
DPete
DPete is offline
Big Kahuna HDF Member
Received 1,735 Likes on 1,302 Posts
I put a little white grease where the spring rubs the stand and where the spring ends pivot also shoot dry slide in the hinge. Keeps it working smoothly
Old 08-25-2011, 07:56 AM
mrfikser's Avatar
mrfikser
mrfikser is offline
Just to split hairs...the book actually calls for neverseize ..but grease will work fine....
Old 08-25-2011, 08:06 AM
beansSG's Avatar
beansSG
beansSG is offline
It's not that it's noisy. Just when up I can grab it and wiggle it a bit. Just seemed before to snap so to speak from one position to the next, know what I mean.
Old 09-16-2011, 10:21 AM
pug3984's Avatar
pug3984
pug3984 is offline
Did you ever figure out a fix mine is doing the same thing and it is driving me crazy??? Its not noisey just flopps about a inch up and down when it is up seams good and tight when its down.
Old 09-16-2011, 10:28 AM
Guest
Guest
Posts: n/a
I just fixed this very issue on my bike last weekend... all I needed was a new jiffy stand spring, working GREAT now (cost from dealer is a little over $6)
Quick Reply: Jiffy stand loose
