Xeid's, Fuelpack or PC-V????????
Xied's + Fuelpak
Had a Fuelpak on my wife's '09 Deluxe and Xied's on my '09 RKC. I like the Xied's so much I added them to her bike, now she has both and it runs even better than before. I talked with V&H tech support and they told me the two devices work on different parts of the 'band' and it should be fine. Just bought a Fuelpak for my RKC and will install on Friday, I'll report back on the results after this weekend...
xieds only work at lower end of the power range. once bike warms up, o2 sensors with xieds go open loop and the ecm just remembers the last closed loop values. If you make your own xieds using the old DIY instructions, for the money invested, the return is ok. but if you buy them preassembled, the costs of these things is too close to other more flexible solutions.
Yes another tuner question. 2010 limited, I am running a cat-less OE head pipe, V&H Monster Ovals and adding a K&N High Flow filter (RK-3930). I did contact Jamie at Fuel Moto and he recommended the PC V with a loaded map. But this would eliminate the use of the 02 sensors. Not sure if i want to do that or not. I do not want to do anything else to the bike just these additions and the simplest fuel management that will allow the bike to run correctly. Is anyone running the other's (xeids, Fulepack) with these types of mods and what has the outcome been.
I do not want to start the chasing of one issue after the next with pinging or decel pop or **** poor mileage. The bike runs great right now, I just want to install the high flow A/C to let it breath a little better. My 06 is built and I just finished getting that one right after a couple of years.
I do appreciate any and all advice guys.
Running Revolution Performance EMS Tuner and so far, extremely pleased. For something completely plug and play, I don't believe there is a better system out there. Now if like me you want to tinker, you might want to look elsewhere. But I've run ThunderMax, PC3, Pc-V's with and without Auto Tune and I have to admit, my bike has never run so good until I put on the EMS system. My two cents......
BTW, I just went from True Duals to this Fat Cat and the system took a good 100 miles to learn the pipe and it now runs flawless.....
ran with Nightrider X14ied's before I went with the head pipes. Now running PC-V from FM. Getting about 50mpg highway and no heat, decel popping or ping. Noticed stock head pipes had some head dis-coloring - not sure if this was xied's or general issue - nothing now. Go with FM and you have options for future changes at no cost. Ride safe and often.
Yes, lots of guys will tell you how great their bikes run with these tricks. But it's like listening to a guy that has always eaten rotten apples found on the ground...he thinks that's the way they all taste.
If I were you I wouldn't put that K&N into the stock airbox... I would get the Screaming Eagle Stage 1 Air Kit... You will get the most out of the pipes...
As for fuel management...
V&H FuelPak is the way to go if you don't wanna bother with it... You put in your setup online and they give you the values... you set it and forget it...
Thats my $0.02...
RON
Thats my $0.02...
RON
