2005 ultra coughing, dying when warmed up
dont think a fuel controler will fix a problem,may make it worse. try cleaning or replacing the iac (idol air controler motor)its cheep.next look at the tps adjuster screw,looks like an idol screw but its not,it should be locktited from factory if its loose that would mean previous owner tryed to get the low idol sound,the screw is adjusted to the signal sent out by the tps,if its not right it will do what u are describing.
rclong211
08-17-2010 07:22 PM
