Help!!!!! Back breaks went out when going down hill
Old 08-24-2011, 04:42 PM
ubreal's Avatar
ubreal
ubreal is offline
Theirs is nothing wrong with my brakes they work fine. All I am trying to say is if you use only your brakes and not your gears to slow down in a short time like 2 minuets your back brakes might go flat and not work
Old 08-24-2011, 05:01 PM
santajim's Avatar
santajim
santajim is offline
That's why they put that linkage on the other side of the brake pedal it's called the shift linkage as in shift down. Just sayin'
Old 08-24-2011, 08:06 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
In your first post you said the pedal went all the way down. Correct? They may fade but the pedal shouldn't go to the stop.
Bleed your brakes and the pedal won't do that coming down from high altitudes.
It doesn't take much air in your lines.
Trust me. I ride those passes regularly.
Old 08-24-2011, 08:11 PM
springerchop's Avatar
springerchop
springerchop is offline
just drag your feet when your brakes fail. Or just use tranny in first place.
Old 08-24-2011, 08:17 PM
SpiderPig's Avatar
SpiderPig
SpiderPig is offline
If they are hot they will! Ask me how I know.
Old 08-24-2011, 10:49 PM
GreenRK's Avatar
GreenRK
GreenRK is offline
is this road gravel? If not why are you relying on the rear brakes?
Old 08-24-2011, 11:03 PM
the4thgearkid's Avatar
the4thgearkid
the4thgearkid is offline
Holy **** is this dude takin one for the team here.... damn. LOL.
Takes one on the chin for spealling.
Old 08-24-2011, 11:09 PM
wachuko's Avatar
wachuko
wachuko is offline
Never had that issue here in Florida
Seriously, as a few other have commented, change the brake fluid to a better quality (higher temp point) fluid.
Based on this I will look into using Motul instead of the HD fluid...
Old 08-25-2011, 01:09 AM
j1mmy's Avatar
j1mmy
j1mmy is offline
i had that happen once..going down a steep hill on a 69 sportster chopper. only had a banana caliper on the rear wheel.half way down i had nothing.i rode thru a red light and 4 lanes of traffic at the bottom 40-50mph dragging my feet the whole way
Old 08-25-2011, 02:16 AM
ubreal's Avatar
ubreal
ubreal is offline
I have never had that problem before. And I have gone down many passes. It only took about 1 to 2 minuets to cool down then they were working great. The only thing is it turn my rotor brown from the heat, I check the rotor to see if it was warp and it look ok. The whole thing is weird I still do not know why the brake pedal went all the way down to the stop
Quick Reply: Help!!!!! Back breaks went out when going down hill
