Filling Air Shocks
Here is the info from the website.
Sette Air 2 ST-35 Universal Shock Pump
Accurate Inflation Designed for Today’s Top-Line Air Suspension Components.
The Sette Shock Pump is a high pressure, low volume pump that is perfect for adjusting air pressure in suspension components. This pump is capable of reaching pressure as high as 400PSI/30BAR, it features a durable aluminum construction and easy to read analog gauge with bleed valve, to insure you get correct readings every time. One feature that this pump has that others lack is the 2-Stage Non Leakage Valve Release System, this valve allows the user to engage and disengage the pump with out air leakage. Brass fittings and a stainless steel braided supply hose make this one of the nicest pumps out there.
Thanks for any help.
Check out a high end bicycle shop. They have very small bicycle pumps in the $10 to $25 range that work well. Just be sure to get one for a Schroeder valve and not a Presta valve.
I have a couple mounted on my road bikes and have used them without any problem. Various types some have a 6" tube and some fit over the valve. The tube is the easiest to use.
If you are on I-40 east bound in Oklahoma there is a tank rack bag in the ditch with a new HD one in it with some other stuff. ^*#$(@$%.
Got a mile marker for me??
[QUOTE=dawg;8731783]http://www.pricepoint.com/detail/162...Shock-Pump.htm[/QUOTE
I need a pump. Since this gage goes from 0-400 PSI, would the gage be accurate at low psi settings?
