Shift Lever shaft is sloppy
Old 08-23-2011, 06:42 PM
Punjabi Rider's Avatar
Punjabi Rider
Punjabi Rider is offline
Spacer is easy to replace or use a heater hose and cut to size but use some marine grade grease on the shaft to quit it down further.Also replace the sift linkage with heim joints to have a smooth shifting and easy to find Neutral and this will be last time you have to deal with this crappy design.
Old 08-23-2011, 06:58 PM
GzrGlide's Avatar
GzrGlide
GzrGlide is offline
Originally Posted by dawg
There are two bushings which are shown in the primary housing section, 42642-00 is the number for the bushings. Slop might be from rear lever in which case you might develop a shifter shaft leak if not taken care of. Good time to replace all the seals
Thanks Dawg. Thats the exact info I was looking for.
The rear lever is pretty tight. Alot tighter than the front one. Can both of those bushings be pulled/pushed out without the use of an arbor press? If I'm reading FSM properly ( 6-25 ) I need to pull the the inner primary off to press them out and replace them with new ones. Do you have any "tricks of the trade" you could share?
I wish I would have found the noise last week. I just had to have the stator replaced on Friday and it would have been alot easier to do it then. Typical luck.
Old 08-23-2011, 07:17 PM
dawg's Avatar
dawg
dawg is offline
Received 3,232 Likes on 1,846 Posts
It can be done without removing the primary. I've seen it done with the use of a punch or the like. You can measure the ID of the hole, less the bushing and then get a piece of metal rod/dowel from Home Depot and drive it out or rig a two jaw puller
DougW2000
01-09-2019 08:02 AM
GTK
06-29-2016 04:56 PM
CT-Bagger
09-13-2012 09:35 AM
Hoblick
08-29-2011 09:32 AM
PDDGM
10-09-2008 04:42 PM
Quick Reply: Shift Lever shaft is sloppy
