At wits end!!
Gas can get past the rings with no problem if there's enough of it.
this really a no brainer....the rings are worn allowing blow by causing gas in the oil, maybe worn valve guides also..also the compression may be down because of the blow by ...the lowered gas mileage is combination of blow by and riding the **** out of the bike...just my take on it....I would do a compression test both hot and cold and add some oil to the cylinder to see if the compression goes up...this is just my take from the description of the symptoms.....
I see a lot of guys come into the local dyno shop complaining about gas mileage and when the dyno tech takes the bike out and checks gas mileage, the bikes always get good mileage. 9.5 times out of 10, the owner has been riding them hard and expecting cruising fuel mileage. Wouldn't it be great if it worked that way?
Like some of the others, I am a little bumfuzzled on how your fuel management system is putting gas into your oil if you don't have a ring problem.
The rings aren't designed to stop something as thin as gas from getting to the oil. There's not supposed to be unburned fuel after combustion.
I was never able to get good mileage using a PC on my last 2 bikes. Not being a tuning expert, I always had the bikes dyno tuned. My last bike I had tuned twice by two separate tuners, still mileage was low. This bike I decided to go without a piggyback system and went with the SEPST (tuned by the dealer). I now consistently get between 43-48 MPG. I still ride the same and believe me, I don't baby my scoot when I ride it. Again not an expert, just my experience.
