Problem with Sony DSX-200X installed
I finnaly got around to installing my new Sony radio. Thought it was going to sound great..but then no sound. I read in the troubleshotting section that if there was no sound that:The position of the fader control "Fader&Balance"is not set for 2 spearker system. My questionis: Is there anyone with the Sony DSX-200X having this problem and if so how do you set it to a 2 speaker system. My setup is the Sony radio with the Biketronics controler, ARC mini amp with Hertz 6.5 inch speakers. Any help would be helpful ..Thanks.
I have the same stereo and amp as you, and no issues like you describe. Does it have power, just no sound? They do have a little fuse and also a reset button if you accidentally arc it while installing. I run mine with 4 speakers and it sounds awesome. Also ran it with 2 while I was doing the install to see the difference.
Make sure you have your amp wired correctly, and double check all wiring and connections. I did have a bad ground at first and that caused no power, but quickly rectified the problem.
