wheel weights
wheel weights
Does anyone else have this problem, wheel weights (the stick on type) keep coming off wheels. I live in Phoenix and it does get really hot on the road and in my garage. The weights seperate from the tape that holds the weight to the wheel. I have no experience with dyna beads. Any suggestions will be greatly appreciated.
Wheel balancing
I had same problem. My 'BEAUTY' rests in a building with temp up to 105 or so. Adhesive strips would melt and release and no amount of cleaning the chrome? wheels and installing new strips would work. Took a while to get the Dyna Beads in but do see see an improvement in the ride. >500 miles and I like. My trouble with the beads was failure to get the tire off the floor. That figgured out and they went it as instructed. Plan to use them on car and truck also. I'm told they never wear out and can be re-used on next tire purchase. Remove and reuse may be more than the tire guys in my area can handle.
I have ran Dyna Beads for years, they always work. I mount my own tires, and have never had a balance issue. I do not run wheel weights at all.
I just ordered my first set of tires for this ride, and orderd dyna beads to put in them. In the past, (on my VTX) when I started using Dyna Beads, I noticed a big difference in the smoothness of the ride, and the front tire cupping decreased.
I have spokes and run tubes, and reuse the tubes with the beads in them until they are no longer good. When that happens I cut open the tube and re use the beads.
Beary
Ask about "ride rite" next time you get a tire mounted. It's a goop that goes inside the tire and self-balances the tire (plus will plug a leak). Bit expensive (like $15 a tire?), but well worth it (plus no ugly weights on your nice wheels).
Been using it for about 4k miles now and no complaints Although I hear some people using it have problems with the valve sicking open when adjusting air in tire, so just make sure to clear it out after topping off - but it hasnt happened to me yet.
tcabello
12-07-2012 07:20 AM
DK Custom
Vendor For Sale Classifieds
11-30-2011 03:55 AM
