Front Turn Signal On RKC
Is there a way to stop the signal lights from coming on while riding. I just want them to be used as turn signals and not light up while riding. I know we can't be seen enough but, I have the headlight and passing lamps on and really don't want the front turn signals on all the time.
You could remove your headlight and locate the connectors for your turn signals should have a violet...blue...and black wire in the connector and possibly a gray wire for the passing lamps...The wire you want to remove from the connector is the blue wire...It is the power wire for the running light portion of your turn signals
1960lespaul
04-13-2012 08:37 AM
