primary oil
Old 08-14-2011 | 05:04 PM
ownasofttail's Avatar
ownasofttail
Originally Posted by GPHDXLC
Amsoil 20-50
I change it every 5000 miles just because it's easy.
+1 works good
Old 08-14-2011 | 05:08 PM
steelerdude1's Avatar
steelerdude1
my last change I tried ATF Type F, I don't really notice any difference from formula +, other than it's easier to find neutral. I was told that it prevents the jump you get when starting when cold (main reason for trying it) but it didn't make any difference in that. It is about $4.00/quart cheaper. I will probably stick with it unless I find something else that helps the cold start jump.
Stiggy's Avatar
Stiggy
Any cheap 10W-40 dino, changed at 5,000 miles.
I still have the original Compensator, chain, tensioner shoe , ( with M-6 Chain Tensioner,) clutch basket and the original clutch plates.
Shifts like it did when new, and just turned 92,000 miles.
Can't argue with an odometer....
Old 08-14-2011 | 05:20 PM
Wassup8687's Avatar
Wassup8687
Originally Posted by XARAN
Redine VTwin Primary, great stuff, makes your clutch engage real smooth IMO
+1 Works great....
Old 08-14-2011 | 05:44 PM
troop's Avatar
troop
Formula+ now but will go to either Rotella 15w-40 dino or 5w-40 syn at the end of season change. Change it once a year but never has more than 6k on it...
TarzanT
05-24-2012 08:54 PM
campdreamer47
Oil Archive (no new posts)
04-22-2012 08:52 AM
babyray
04-19-2011 07:36 PM
electra glide
02-06-2011 07:30 AM
hdpearson13
Ironhead
12-13-2007 07:49 PM
Quick Reply: primary oil
