I think Ive done my homework, but need to make sure!
So I have a 2011 Street Glide 96. My problem is it pings like no one's business under any type of acceleration. Sounds like Im winning high score in a pinball machine under my legs. Now the only change i made was I put V&H Twin Slash slip ons on. I never changed anything else at the time because I was told I wouldnt have to, everything would adjust itself. So, now Ive looked into it and from what Ive read on here Im thinking this sounds like my solution:
1. I change over to jackpot headers to get rid of the cat and heat.
2. Add a Stage 1 A/C for more air
3. Get a PC5 from Fuel Moto to adjust fuel/air mixture to get rid of ping from bike starving for fuel.
I plan on keeping the slash cuts for my pipes and just plugging them into the packpot headers.
Does that sound like a solution to those running issues?
in my case pinging was solved with XIEDS ( $125 shipped plug and play).
but yours may be more severe - I'd get it in for warranty service first while you can, persistent pinging will burn a hole in your pistons- burn up the combustion chamber etc.
---- and the changes you are considering would probably make any warranty claims void.
( with the XIEDS, you can just unplug them before going into the dealer)
In my case pinging occurred at 2800-3200 rpm on 6% grades. It was repeatable.
And occurred in completely stock trim.
nightrider.com XIEDS solved that, and allowed me to switch to a high flow air cleaner ( Ness BS) and performance exhaust. Mileage was for the most part unaffected, 44 mpg or so when touring
An easy low cost solution.
Mike
Mike
Here is a thought, put the stock mufflers back on and bring it to the dealer for WARRANTY service. If you think that a different headpipe is going to solve a detonation problem you are wrong. Mufflers will not change your A/F ratio beyond what the ECM can adjust. Bring it to the dealer before you burn a hole in the pistons!!!!!!!
first are you running super, octane 92-93 if not you should be and are you getting your fuel at a cheap no name station.some fuels are junk.try shell or mobil.if all fails bring it to the dealer.as far as fuel moto great choice,i have fuel moto stage 1 a/c,jackpot 2-1-2's,4" rineharts and pc-v with 2 maps i had to adjust 0% throttle from 1750 -6000 with + 20 to get rid of decel pop but its runs fine now.
Blvfisc
12-15-2014 02:31 PM
Port Dawg
02-09-2011 06:48 PM
