V/H dresser duals with Rinehart slipon's
I have the basic set up you are looking for. added the V&H DD after the Rinehart SlipOns and the change made a significant change in the noise - good. soft at cruising speed and bark when you add the wrist. Some say lose of tourque at the low end - maybe true but what is missing at the low end you make up from the mid range and up. temps are way down - little to no heat. no regrets and lots of room for a displacement upgrade if you go that direction.
I would say your "dealer" forgot to put the spacer washers in to offset the floorboard away from the heatshield. It is an easy shortcut to the install but the result is exactly what you experienced. sometimes a fraction is as good as an inch - especially if you know what you are doing.
Possible but wierd - sounds more like a damage issue or sloppy installation. Oh well - enjoy it and ride it because you don't know what tomorrow will bring. Ride safe and often.
V&H DD w/4" Rineharts!?
Sorry to reply to an old thread, but I must be missing something.. Can anyone explain how they are using the 4" Rineharts with V&H Dresser Duals? The inlet on the 4" Riney's are 2" where the DD's are 1-3/4?
I wanted to do this to my '12 FLHTK but spoke with both manufacturers who both confirmed it wasn't possible. The 3.5" Riney's would work.
I just ordered a set of 4" slip-ons.
SKU: 500-0102
NEW 1995-2012 4 Inch Slip-on Muffler Chrome *Do not adjust stock ECU settings with Rinehart slip-ons on 2009-2012 H-D Touring models with stock head pipes. **This part will not fit Rinehart Racing stepped header systems.
