Why Not Mobil 1 V-Twin 20W-50 in Tranny?
Not trying to create a maelstrom, but...
IF MoCo recommends a 20W-50 lube in all three holes, then why aren't more folks using Mobil 1 V-Twin 20W-50 in their transmissions?
A quick look at some numbers indicates that Mobil 1 V-Twin 20W-50 compares very favorably to Mobil 1 LS 75W-90:
Mobil 1 V-Twin 20W-50 Oil
Viscosity Index 142
Pour Point -42
Flash Point 214
Mobil LS 75W-90 Gear Lube
Viscosity Index 142
Pour Point -39
Flash Point 150
Just sayin'...
Viscosity Index 142
Pour Point -42
Flash Point 214
Viscosity Index 142
Pour Point -39
Flash Point 150
Just sayin'...
2019 Heritage Classic 114 M8 (09-23-2021)
You could and it would be fine in all likely hood. I would not because the numbers you listed do not tell the whole story. I use Mobile 1 15-50 in the engine and I use a gear oil in the trans. The reason I use a gear oil in the trans is because of the extreme pressure additives used in gear oil. In my research and understanding, motor oil has additive packages meant for the motor and gear oil has additive packages meant for the trans. But hey, it is a free country and it is up to you. As I stated earlier it will probably be fine.
The Mobil 1 V Twin 20w50 is fine for all 3 holes. Says so right on the bottle and I'm sure they know a little more about oil than we do. I would say there are some better alternatives for the tranny to make it quieter but I have known people that have ran the Mobil 1 in all 3 holes without any issues.
Viscosity Index 142
Pour Point -42
Flash Point 214
Viscosity Index 142
Pour Point -39
Flash Point 150
Just sayin'...
Viscosity Index 142
Pour Point -42
Flash Point 214
Viscosity Index 142
Pour Point -39
Flash Point 150
Just sayin'...
