Intermittent low idle and stalling
Just an up date, drained the gas tank and added injector cleaner, and swapped out the TPS. no help. Checked for air-intake leaks and found no problems there. I'm in the process of draining the tank again and will replace the hoses. Hope this does it cause I'm running out of ideas.
No codes till this past week after buying the parts to change out fuel internals for the efi. More on that in a moment.
Bike would run well with a full tank of fuel, but with the last qaurter she would stumble and want to stall out , especially in stop and go traffic.
Top off with a full tank and she would be good to go. so after three tank fulls of this I figured it was the fuel line troubles that I had back in 2006 (my bike is an 02 btw)
After the last episode I figured it was an internal fuel line leak, bought all parts and was ready to tear into it on Friday before work when I decided to check for codes one last time as now the check engine light comes on and stays on for 15 seconds and then bike runs like a pos...
The code that came up was/is P0505(historic) loss of idle speed control. I shot some wd-40 around the intake checking for leaks , found none, so it appears I need an idle speed controller for $72.00 at my local dealer.
Returning the parts for the fuel tank internals for one of those iac thinggies.
So, I'll add the parts needed to swap put fuel lines and filter, etc...
10 of 1311D sealing screws @$1.39
1 of 10222 clamp 8mm @ $3.69
1 of 61402-02 gasket, top plate @$8.39
1 of 61001-01 fuel filter kit @ $93.95 and this should include an o ring and two 8mm clamps.
1 of 61408-00A body assembly check valve @ $76.95
1 of 62349-04f fuel line asy tank to intake @ &59.95.
I posted this for information purposes and I know these items can be sourced cheaper online but one needs the shopping list first and prices where full blown retail here in the Vancouver Canada area.
Hope it is of some use to the OP.
Rob
Replaced the hose between the filter and fuel pump. Check the hose from the pressure regulator to the quick disconnect and it's fine. Checked the 0-rings and they look good, so I don't the problem is in the fuel tank. Also above 2000 rpms, the motor seems to run fine. It's between 900 to 2000 rpms where it backfires and misses, and runs like $hit. While I had the tank off, I pulled the injectors and sent them out to be checked and cleaned.
Mine is too...fires up fine, idles above 1000 for 10-15 seconds and then will drop to a lovely 400-600 and eventually stall if I don't keep the throttle open just a hair to give it gas. Only does it on idle or when at a stoplight. Riding is fine though.
I checked the map on the PCIII, tweaked it, loaded a new map and still the same thing. I guess I need to search the forum and eventually tear in to this old thing...
forestfarm
09-04-2020 06:30 PM
macnab_sf
06-16-2020 04:23 PM
