ABS wheel bearing upgrade part number
2009 RKC with ABS. Im about to change my tires and thought while I was doing it, I'd upgrade the wheel bearings since Ive read so many threads here with the OE bearings sucking. Anyone have the part number for the Timkens for the new bikes with ABS? Thanks...
That's interesting. I just sold my BMW, which had a series of 'teeth' round the inner diameter of one of the brake rotors. I assumed Harley had done something similar on a smaller scale on the wheel bearing, moving on a generation or two from my old BMW.
Of course Dawg is only writing what his lovely lady tells him!
there are little "windows" inside the seal portion of the brg, as the brg rolls the sensor picks up the broken field caused by the windows, if you lock up the wheel, the sensor sees that its not moving (or moving at wrong speed) and activates the pump which starts to control the amount of pressure on the rotor. this keeps you in control by allowing you to steer, but does increase your stopping distance
