Honest Review of Motorcycle Metal and Ohlins
#161
Look up the High Seas Rally, we have many people from the UK on the cruise.
Looking forward to installing the Ohlin shocks. They won't be here until January and that is the middle of winter in little Rhode Island. If we get a day about freezing I'll be out for a test ride.
#162
January wow ! If you ordered them from Howard they would be cheaper and you would have them in a week. On the last set I ordered from Howard for my wife's sportster he threw in a second set of springs just in case she wanted a little softer ride. I didn't ask for them, he just included them in the box with a note. Just sayin.
#163
You can bottom out many times and never know it. I think what most people are referring to is bottoming out with a thud and driving the seat upwards. Bottoming out lightly can occur quite a bit and unless you have a zip tie on the shock shaft as reference you won't know for sure, unless it's a bone jarring event.
#164
#165
Most (all?) manufacturers provided some form of multiple rate spring (i.e., the rate, lbs/in, varies from less to more with preload and as the rider load increases). They do this so a single suspension setup can support the light single rider as well as the bulky Harley guy with his sveldt spouse/gf, with only a twist of the preload setting. It's not all bad, because a lot of us do just that.
That said, it is pretty uniformly asserted by racers and suspension folks that suspension performance is significantly better with single rate springs tuned for the bike weights, rider weight, shock damping setup, and riding style.
Best,
#166
Wow, that's awesome. Your right, yours were much cheaper ! Enjoy them.
#167
to me (I already own ohlins (ordered from a re-seller at a very fair price (not MM), but after ohlins usa talked with me extensively about set-up options).
I knew a litle about shocks, but knew a lot more about the type of roads I ride and how I ride.
I think it would be a great service the MM customers for MM website to be re-designed into an easy and understandable format.
I think Howards frustration (and resultant attitude to potential customers) would be reduced if the above were implemented.
I also think the Howard could explain on the website just what precisely goes into "building" or setting up the shocks a customer chooses, there-by making them "their decision"
I believe that basically consists (after deciding style) of deciding spring rate, valve action and oil weight. This is where the customer has no knowledge.
If the website is not easy to understand, or lead a customer to understand how a shock works, just how is the customer to decide, AND THEN know that the shock they spent $$ on was the appropriate shock?
The average buyer may become disheartened with the MM site and leave without moving to the point of buying.
#168
an overwhelming number of people attest that Howard not only talks with them and explains and answers all questions, but also does follow up.
There are a handful that say they did not get that treatment, that he was gruff, had attitude, but you and I were not part of the conversation.
Another happy customer just posted yesterday. notice that he sent Howard an email and Howard phoned him when an email reply would have been enough.
I agree the website needs to be tweaked, but his customer service makes up for it.
#169
oh, no doubt. I found the site after I bought my shocks. my post was purely me feeling after looking the site over as I have been researching front end improvements.
progressives, ricors, howards, oh! my!
I do know the front end dive of a heavy tourer with my tall 200# frame is not going to continue much longer
