Honest Review of Motorcycle Metal and Ohlins
#151
My friend says, if you don't bottom out once in a while, that means you're not using the full travel of your shocks.
#153
Not sure of the spring rate. I'll send them an email today. What is the difference between single rate and progressive rate?
#154
When buying premium shocks like Ohlins I would hope they come with springs and damping matched to you and your ride. That means single rate springs. Progressive-rate springs are a compromise, but common on cheap suspension systems.
#156
he said: If you did not go on just one of those cruises, with the money saved, you probably could purchase the shocks.
#157
Yup! I was just having a little fun, that's all.
#159
They obviously haven't enjoyed thousands of miles of bottoming-out free riding!
If you skipped one of those events, could you afford a set as compensation?!
Look up the High Seas Rally, we have many people from the UK on the cruise.
Looking forward to installing the Ohlin shocks. They won't be here until January and that is the middle of winter in little Rhode Island. If we get a day about freezing I'll be out for a test ride.
