woods 555 vs se204 cams
I've got the 204s and 1.725 SE rockers in my 103 bike. No clearance problems with the stock flat tops and stock heads. Theoretically, the high ratio rockers should be good for an additional 3-4 hp/tq. I didn't run the cams without the rockers, so couldn't speculate whether or not they made a noticible difference.
Have you concidered the SE 254e cams?
I'll tell you what go here and read up on
SE cams http://www.harley-davidson.com/wcm/C...bmLocale=en_US
The higher lift will show up on a dyno if the heads are ported. IIRC, 204 lift is .508" and stock head flow flattens out at .500" but ported heads will flow to .600", or at least they should.
4HP/TQ for $138; that's about $35 per; not a big absolute gain but pretty cost effective compared to the cost of other upgrades in terms of $$/HP-TQ.
Received 49,910 Likes
