Purchased the RBT module w/red turn lenses for my 09' SG.. like the idea of more light on the rear...problem is when I turn ignition switch to acc. side for changing cd's or tuning radio in before i ride , turn signal lites stay on .
Never noticed that before. Is that normal?
They are RUN, Brake, Turn signals now, so they would stay on. Hit the turn signal switch for either direction and that one should blink.
Not sure but I think what the OP is asking is if that's normal with the ignition in the ACC position. I have the kit installed and to be honest I never noticed if they are on when I'm on ACC. Definitely stays on in run mode though.
My bike came standard with that (2010 Road Glide), and it does go on in the acc postion.
I knew that the taillight stayed on prior to the install (not the sig lights) the turn signal only lit when left or right was used....... now since the module was installed the turn sigs stay lit just like the tail light in the acc. position...and they do blink when the right or left switch is used. Would have thought sig lights wouldn't lite up in acc. position..
New circuit for the extra RUN lights taps into the same circuit as the original RUN light (tail lamp).
Running and blinker lights work in acc so they can be used if broken down on the side of the road. Blinkers then become four-way flashers too.
Had one on my 2008 Ultra and the rear running lights did not come on in acc position, on my 2011 they do (tailight stays off) and I hate that because I like to hear the tunes while I work on it or clean. I believe it's normal for 09+.
