TTS and other tuners
Old 08-08-2011, 07:17 PM
crackers's Avatar
crackers
crackers is offline
I wasn't asking this question for the reason of wanting to change but for future reference if I sold the bike and maybe the new owner preferred a different tuner so it was more out of curiosity.
Old 08-12-2011, 04:52 PM
hrchdog's Avatar
hrchdog
hrchdog is offline
Originally Posted by crackers
As of tonight everything is installed. Stage 1 air, V&H Power Duals and of course the tune from the TTs.
Originally you posted that you were putting on a fullsac x-pipe, what made you decide to change to the v&h power duals?
Old 08-12-2011, 06:21 PM
PLEIKU69's Avatar
PLEIKU69
PLEIKU69 is offline
Guys need your help while you're talking about TTS tuners. A friend of a friend screwed with recalibrating my ECM without my knowledge and my bike started running like crap. My question is can my tune be screwed up by doing this or is it just a fluke.When I first started it it idled at 1500 so I ride it around the block and finally idled back down. It also seems to have alot of slack before the throttle catches up which I know is a tbw but it is different than before. THANKS
Old 08-12-2011, 09:52 PM
mjb765's Avatar
mjb765
mjb765 is offline
If he meesed with your existing saved map and then loaded into the ECM, yes--depending on what he touched--the bike could very easily run like crap. If you have a copy of the map you had loaded without any changes that your friend made, I would just reload that one. That will put you back to where you were before he touched it.
Old 08-12-2011, 10:15 PM
mtclassic's Avatar
mtclassic
mtclassic is offline
well it is normal on first start up for idle to be high with tts. takes a minute to come down. how the heck did someone mess with your ecm is what I would like to know. any way it is easy to reload your last tune.
Old 08-12-2011, 10:48 PM
crackers's Avatar
crackers
crackers is offline
Was made a deal on the V&H that would of been dumb not to take. After Steve gets a good stock of his pipes on hand I will be trying them also.
Old 08-13-2011, 07:32 AM
PLEIKU69's Avatar
PLEIKU69
PLEIKU69 is offline
Thanks guys for the info.What he did was to turn switch on 10 sec off 10 sec for five times and start on sixth as I was told anyway.
Old 08-13-2011, 07:40 AM
mtclassic's Avatar
mtclassic
that should not mess up your tts tune.
Junker
07-07-2014 12:38 PM
johnnyt5646
10-20-2013 09:30 PM
jackinthebox
04-07-2010 02:00 AM
mgabr00
12-27-2009 03:40 AM
Glenno
03-30-2009 12:44 PM
Quick Reply: TTS and other tuners
