Wife and I went down...word of caution
A new one...at least I have never heard of this happening. I just had new handlebars and cables installed and I have ridden a couple of thousand miles with them with no problem. Yesterday pulling out of my driveway I turned to the left. When I tried straightening out the bike it would not turn back to the right. Was like my forks were locked. I was looking down at the front of the bike wondering WTF and when I looked up we were heading for neighbors front yard with a pretty steep ditch. Anyway we hit the ditch and down we went. Luckily neither of us was hurt nor the bike. When I got the bike back up I noticed I still could not turn the bars to the right. Then I saw what caused it. My clutch cable had hooked on the bottom bolt to the windshield bracket! Obviously the whole event scared the s#@t out of me and my wife and even more so when I started thinking what if this would have happened at high speed. Don't know why it waited this long before it happened unless somewhere along the route of the cable something broke loose causing me to get way to much play. It will sure be something I check before each time I ride again. It will be going back to the shop for a re-route of the clutch cable.
Glad you and your lady are ok and the bike wasnt damaged too. My wifes bike, XL883L had a similar situation in that when we ordered it, I got the dealer to fit an 18" windsheild. Well she had put no more than 50 K's on the bike when I saw her nearly run up the rear of a car. When I pullled up along side she said the bike kept on going and wouldnt slow down. I thought WTF and told her to pull over so I could check it out. Couldnt find anything wrong and thought perhaps being a new bike she just needed a little time to get use to it, especially after riding a virago for some time. Later that same day at a mates house she started it up and all I could hear was this little 883 screaming its guts out. Well as it turned out if you turned the bars in one direction slightly the throttle cable would lock up because the cable was routed under the windsheild clamp. Undid the quick release clamp and re-routed the cable over it and all was good. Either way I just check the cables and make sure the throttle cables arent pulling tight when the bars are turned, when she adjusts or puts her sheild back on.
Guess I'm thinking more that if I had been pulling out into traffic on a busy highway it could have been a disaster. If I had known what I know now was causing it I could have maybe reached down and unhooked it from where it was hung up. When it happened though it felt like my front end was completely locked up and I felt helpless.
Kill switch?
Pull in clutch?
Brake?
Glad you are OK, and don't mean to be harsh- but you should be thinking about these things.
The text book instructor guys say you may have noticed this problem before starting the ride when inspecting the bike. Most of us don't bother but...
Mike
Pull in clutch?
Brake?
Mike
Kill switch?
Pull in clutch?
Brake?
Mike
Pull in clutch?
Brake?
Mike
