Is there much difference in Polly Riser Bushings?
Old 08-04-2011 | 12:02 AM
C908's Avatar
C908
Default Is there much difference in Polly Riser Bushings?
I'm getting ready to order Wild One 577's along with Polly riser bushings and they are only $10.95 for four at Dennis Kirk. The price is so low it makes me wonder about the quality. I think I saw some on another Website for $19.95. I know they are higher than that at a dealer. Anybody have an opinion? Thanks.
Old 08-04-2011 | 12:22 AM
FFHD05's Avatar
FFHD05
ive used both the HD ones and the drag specialties polly bushings..deff worth the money much firmer feel..as to what brand...polly is polly..i only bought hd becuase id forgot to order the drag ones and they had the moco ones in stock...im impatient...lol
Old 08-04-2011 | 12:28 AM
pargenz's Avatar
pargenz
If you're gonna replace bars why wouldn't you install polyurethane bushings instead of the washer setup that's stock? Especially for 11 or 20 bucks...
BTW, what isn't higher at a dealer?
Old 08-04-2011 | 12:32 AM
mkguitar's Avatar
mkguitar
I found no advantage to poly bushings- the difference is in how hard the bushings are tensioned.
I was able to 'tune out" many of the vibrations that were giving me problems with my hands going numb.
I did the R&D on my FXR where you can get to all that stuff alot easier.
my 2¢, save $10
Mike
Old 08-04-2011 | 01:33 AM
C908's Avatar
C908
I am going to replace them it's just a question of which ones. I was just wondering if the cheaper ones are just as good as the more expensive ones. Sometimes it's just a question of how much mark up an item has that effects the price.
Old 08-04-2011 | 06:50 PM
DougM's Avatar
DougM
I got the Harley ones off eBay for about $10. Worth the upgrade in my opinion. Less vibration affecting the carpal tunnel wrist.
Old 08-04-2011 | 07:51 PM
BigMike17's Avatar
BigMike17
Well worth it - I went with the Harley ones on my last bike and they made a huge difference -
Old 08-04-2011 | 10:52 PM
Da Butcher's Avatar
Da Butcher
A leisurely rider may not pick up on all the advantages, but they're definitely worth it. Bars don't vibrate as much. Big difference in quick directional changes, less rubbery in feel. Steering is more positive. When you make a quick left/right steering input, the change is MUCH more immediate because the bushings don't have to compress that little bit the way the rubber ones do before your steering input reaches the forks. Tightening the riser bolts won't do squat for lateral movement which is where a large difference can be felt.
Do it, it's a cheap upgrade you can feel an improvement on.
Khloesdad
08-21-2018 05:11 PM
Yul B. Nekst
01-30-2013 08:20 PM
pheur
05-12-2012 08:19 AM
SC-Longhair
06-23-2009 10:45 PM
mebe007
03-04-2009 07:07 AM
Quick Reply: Is there much difference in Polly Riser Bushings?
