Best Cables on the Market?
The HD cables are rebadged Magnums I believe. I bought one of their clutch cables to replace my Barnett cable and it was substantially nicer. Only issue is their protective sheathing is not terribly durable, make sure your cables are routed correctly.
Goodridge is the best choice for brake lines, IMHO.
I agree that the Magnum cables are very fragile on the coating. I had ordered a a +4 when I put the Wild 1 575 bars on and there were no instructions. The adjustment lug is backwards from the stock and when I went to adjust it, it came apart which makes it pretty much useless. My screw-up I suppose but I ordered the +4 from Barnett direct and am very satisfied with them. Attempting to route the Magnum through the fairing resulted in several cuts to the outside sheathing. The Magnum were attractive, but I consider a cable to be a functional item, not show item, and I prefer durability and reliability.
ZeroFiveFour
12-20-2008 10:40 PM
