Supertrapp 2-1 vs Fatcat 2-1
Old 11-11-2006 | 09:31 PM
maineultraclassic's Avatar
maineultraclassic
Default Supertrapp 2-1 vs Fatcat 2-1
Between the Supertrapp 2-1 or the Fatcat 2-1..........which one gives the best performance?
How does the sound of each compare to the other?
I like that the Fatcat is available with the falsee to keep the ***-end balanced, too bad the Supertrapp isn't.
Thanks,
Steve
Old 11-11-2006 | 11:11 PM
jeepster09's Avatar
jeepster09
Default RE: Supertrapp 2-1 vs Fatcat 2-1
The FatCat's are louder and don't make quite as much torque.
Old 11-11-2006 | 11:14 PM
maineultraclassic
Also, if anyone has any pictures of the Supertrapp on a bagger..................can you please post them?
Thanks,
Steve
Old 11-11-2006 | 11:19 PM
jeepster09's Avatar
jeepster09
Here are a couple.
[IMG]local://upfiles/1346/850AF0A82D924138B907A43305755FEC.jpg[/IMG]
[IMG]local://upfiles/1346/C0AC6B7864714F87A7428D8A955CE641.jpg[/IMG]
Old 11-11-2006 | 11:24 PM
Harleypaw's Avatar
Harleypaw
I have the Supertrapp 2/1 and have dyno charts to prove the power difference.
I have run the D&D fatcat, the Thunderheader, and the Supertrapp, out of the three the Supertrapp makes the best power and is quiter than the others. I do like the D&D for the sound and the false, it would be my second choice.
I'll try to scan the dyno charts and figure out how to post pic and charts
Old 11-11-2006 | 11:36 PM
maineultraclassic
ORIGINAL: Harleypaw
If you can't figure it out, email them to me and I'll post them for you.
Steve
maineultraclassic@maine dot rr dot com
Old 11-11-2006 | 11:54 PM
Harleypaw's Avatar
Harleypaw
I haven't taken pictures with the Supertrapp yet, I'll do that tonight and e-mail to you. I'll get someone to scan dyno, as you can tell I'm a motor head a little computer challenged
Old 11-12-2006 | 12:39 AM
PhilM's Avatar
PhilM
ORIGINAL: jeepster09
Although I am not an engineer, this was explained to me by someone that is and is in the performance exhaust business. The effect pipes have on performance and where the power is available is directly related to signwave reflections that occur within said pipe.
In very crude "lei person" terms (appologies in advance for brutalizing the science here)..... A pipe will have performance characteristics that directly follow a signwave. For example, some pipes have a tendency to deliver torque (as you read a, from left to right, as RPM increases) in a "low, high, low" pattern, meaning that the torque curve is highest in the center. Other will deliver torque just the opposite, or "high, low, high", meaning that they are strong very low and droop a little in the center and then come back up towards the high end.
The SuperTrapp (much like the old WhiteBros E-Serise) is a good and very tunable pipe that delivers peaks in the center and is lower both early and late.
The D&D is the opposite. It is very strong early and dips a little and then comes back up on the high end.
If you look closely at several dyno sheets you will begin to see this tendancy. It is more pronounced on some than it is on others.
There is an EXCELLENT exhaust comparison that was done for several Buell exhaust at this location: ftp://ftp.americansportbike.com/outg...est_Report.zip . If you take the time to read through all of this, it might help clarify some of what I tried to say.
I had an E-Series on my first RG and it was a great performing pipe, but it sounded like ****. I bought a FatCat when they were 1st released and have never looked back. I have a 2nd FatCat now on my new RG.
I, too, have played "chase the pipe" and had ProPipe, E-Series, ThunderHeader, and 2 FatCats. "To me" it's the best there is.
Here's a sample dyno sheet that can be compared to some that others will undoubtedly post. The red trace is the FatCat.
[IMG]local://upfiles/8665/58B9060DDAB34F1BA8C8ED0EBE658FA4.jpg[/IMG]
Old 11-12-2006 | 01:44 AM
rideon's Avatar
rideon
Steve are you really thinkin about gettin' rid of those beautiful rineharts? I thought I had a bad exhaust system addiction, but you have got me beat!
Old 11-12-2006 | 02:03 AM
maineultraclassic
ORIGINAL: rideon
The Rineharts are my 7th exhaust setup in a year..............so I'm well known for swapping out.
I'm really not sure what I'm going to do. I love the looks and sound of the Rineharts, but I know I'm going to leave a bit on table in the power department. By going to the Supertrapp 2-1, I'll gain some power.......... and the looks are good, but my major hang-up is the 1 pipe out the back. Everything on a bagger rearend is symetrical, and by removing 1 muffler you throw off the visual balance.
That is where I'm at right now...........totally undecided.
Steve
