Having problem getting cord from Headlight
I have searched removing the headlight for the cord and what I get is just that, disconnect the cord from the light. Well I am either missing a trick or soemthing is wrong. I have tried, pulling the clip from the bulb with even peasure, even tried very hard to the point that the spring and black rubber cover damn near come off with actual light bulb attached. Almost like there is a clip or something holding the clip itself to the actual bulb prongs. So, am I missing something here?
Sorry if this is a very dumb question, but I am having a problem with it and it is kinda embarassing....
Thanks for any help!!
You're not missing anything, they're just tight as hell sometimes. The connector will pull from the bulb eventually. The first time I did mine I removed the clip, took the bulb out of the housing, put my hand in a plastic baggie (so as not to contaminate the bulb's glass if I touched it) and pulled by the metal base of the bulb and the rubber 'case' that has the 3 connectors in it. When I put it back in I put a dab of dielectric grease on the prongs
Received 49,953 Likes
Location: Western Illinois, land of bad roads, and corrupt politicians
