Major problem
Major problem
The front spark plug hole stripped out on my 2002 EGS tonight. I just bought this bike about six weeks ago and have been working on some minor issues. One of them was running to rich. Going by one of the procedures on this forum of using three sets of new plugs and adjusting the air idle screw running it and check the plugs for color. While doing this I noticed the rear plug would screw all the way in and snug with the ratchet in about 1/2 or 3/4 of a turn but the front one would only screw in about 2 or 3 turns by hand and then I would have to tighten it up with the ratchet. It didn't turn hard but I still had to use the ratchet. While doing the last set as the plug start to snug up just spun free again. It has no threads at all, the plug just sits in the hole and spins freely.
My question is can I just pull that head off and have it retapped or replace it and reassemble it or do I have to do the whole upper end
This can happen due to over torquing & stretching the internal threads, not using anti-seize or pulling a hot plug from a hot head.
Head is Alum so...It can be welded up & re-tapped or a heli-coil can be inserted. If you only replace the one head, be sure to clean out the alum shavings from cylinder really good.
Best alternative is to by a good used complete head & replace it. All the other valve parts are reuseable.
A Matched set of low mileage heads is the better choice. That way, you can replace all the gaskets & such with new ones. If you got an 88 incher, great time to step up to a 95 kit.... And it begins....yeah, its mo-money!
sorry for your luck.you have a few choices.you can get a helicoil kit repair to repair the threads.you have lots of room to work at it.ask your local engine machine shop what they use. you may want to remove the heads and get them polished and ported.it isn't really a very big problem.good luck
Big-sert spark plug hole repair kits are the best quick fix on the market. Don't waste your time with heli-coils. The beauty of this method is that you can have your bike back on the road the day after you get the kit and you do not have to remove the head if you use care. I did my first few repairs on the bench to see how much debris I lost and there was zero. Spend some time to make SURE you order the right insert. The replacement threads will outlive you if treated with respect, i.e., don't remove plugs from a hot head.
http://www.timesert.com/html/sparkplug.html
Video:
http://youtu.be/a5k9rEeGUTg
Video:
Retapping will not repair a stripped out hole. Even if you are successful in getting the tap to clean what threads remain, under heavy acceleration you can blow the spark plug right out of the head. I've seen it happen.
