2011 Street Glide help(just bought it)
If you want accurate, this gauge will fit the bill.
http://www.dakotadigital.com/index.c...326&prd326.htm
x2 on the Kuryakn floorboard extenders. I also have a 34 inch inseam and wear a 13 shoe. I wanted both forward AND out and the Kury extenders did the trick.
Check into a Mustang seat. It should put you back at least an inch. Mustang also has a driver backrest available.
Look into the HD detachable sissy bar with pad. Easy on, easy off. I have an accessory book, so let me know if you need part numbers.
I have harley goodies extentions that move the boards out. Then my highway pegs are mounted on the crash bar low enough that I put my toes on the pegs and heels on the boards. Works good for me. As far as a seat goes, I just bought an 08 Roadglide seat that moved me down a little. I am going to have mean city rework it so it will move me back. Before that I had a CVO seat and it work great for lowering. Cant help you with gauge and tour pack as I dont have those. Good luck.
I have been using the Harley Goodies extensions for years...they make a difference.
Highway pegs on the crash bar will definitely increase your comfort. Especially ones that are adjustable on the fly. Check em out!
Kevin
__________________
TRICK!?!? From Harley- See Here
OR
TREAT from DK Custom Products ~ 10% Flash Savings on All Air Cleaners, use Code: Clean10
DKCustomProducts.com
OR
heres my question. I look up the tallboy seat on HD site and it says it will use a rider backrest but there is no cut in the seat for it so I am lost. I need a backrest as I have L3-S1 fused in my spine. The floor boards kit I will check into.
You're getting some good info from everyone.
Kevin
Kevin
Well, you have to lift your foot anyway to actuate the brake pedal. On the shifter side, I just leave my toe under the shift lever and upshift as needed. When it comes time to downshift, I have to move my foot, yes. I don't use a heel shifter on this bike.
That's another thing. I'm trying to get my head around a heel shifter. Having to lift your foot up, move it way back to shift when you can just leave it in one place and do both is what makes sense to me. I seem to think that my right foot pretty well stays in the same place when braking also.
1. Kuryakyn Relocator Brackets - out 1" forward 1"
2. HD Tallboy - 2" back, or Mustang Super Touring Vintage - 1.75" back
3. ???
4. 4-Point Docking Hardware Kit
3. ???
2. Add "Mean City Cycle" seat mod to the mix.
3. HD gauge is fine - ton of owner/rider posts agree
4. Agree & get tour-pak pad
Congrats on becoming a member of the touring class & I have same 34" inseam. HarleyGoodies 1" extenstions worked fine for me + added HD short-angle pegs to crash bar. Enjoy & ride safe!
