rear tire alignment, belt tensionser alignment
This is true unless you are installing a custom rear wheel and compensator. If this is the case, make sure the drive side spacer is the correct length. If it closes or opens the arm spacing, it will cause the pulley to track the belt to one side.
Location: Western Illinois, land of bad roads, and corrupt politicians
Good tape measure from center of axle to center of swingarm pivot, if you want to check it.... but the cams should align it for you, unless the right one is sloppy on the axle.
If you want to do the florescent tube thing. Have someone hold the tube against the rear tire, while you measure the distance from your front tire with the wheel centered. Then do the same on the other side and compare measurements.
Try not to drop the tube.........
That only works if the cam on the nut side fits nice and tight. One side is solid on the axle, the other is a square hole that can get sloppy. Never hurts to double check with a tape measure.
The belt tensioning procedure accounts for the slop in the right side cam, you can't tighten and then back off a little. You only can tighten the cam until you acieve correct belt tension, if you get it too tight you have to completely loosen the cam to take the slack out of it, and then tighten again.
