Notices
Bad gas mileage
Old 07-25-2011, 08:39 PM
nail bender's Avatar
nail bender
nail bender is offline
Default Bad gas mileage
i have an 05 FLTRI with 95 inch kit screamin eagle slip on mufflers se 211 cams k&n filter and race tuner.(THIS SETUP HAS BEEN IN THE BIKE FOR AS LONG AS I HAVE OWNED IT) my cam chain tensioners were bad so i went with the upgrade kit and put in new lifters as well. it started right up after putting everything back together, and runs as good or better than before. but my gas mileage has dropped from 40-42 down to 32-35. is there something i could have done to affect my mileage like this? i have put 650 miles on it after puttimg it back together and that is the mileage i got. riding the same as i have rode it for the 31,000 miles i put on it before the tensioners went bad. could i have done something wrong or is this an unrelated problem? thank you for any help
Old 07-25-2011, 08:58 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
sumping.
Old 07-25-2011, 09:05 PM
nail bender
how would i check to see if this is what is going on?
Old 07-25-2011, 09:14 PM
bigdumbnoitall00
im not an expert on it but what little i know something about setting up the oil pump not just right will let oil build up in the lower case,check it by removing a drain plug under the crank and measuring how much oil comes out, youll have to do a search on the amount unless someone else chimes in.
Old 07-26-2011, 10:37 PM
nail bender
i drained the crankcase after riding 480 miles, and got out a little less than 8 ounces. is this normal or is this enough that my engine may be wet sumping?
Old 07-27-2011, 07:38 PM
nail bender
anyone else got any ideas on this ?
Old 07-27-2011, 07:43 PM
Lonewolf176's Avatar
Lonewolf176
Lonewolf176 is offline
I'd suspect it's in the tune.
Old 07-27-2011, 08:39 PM
shooter5074's Avatar
shooter5074
shooter5074 is offline
Location: Western Illinois, land of bad roads, and corrupt politicians
I had pretty much the same bike and engine.... but I had the SE active performance exhaust and stage 1 intake. I averaged 35 mpg. I think it was my right wrist causing the problem....... I would look there first
Old 07-27-2011, 09:56 PM
Mr.G's Avatar
Mr.G
Mr.G is offline
Ive got an '06 FLHPI with SE Stage 1 cleaner and Bub slip ons - similar problem last tank was 31 mpg - 1 time I have gotten 40 mpg - probably a 35 mpg average in 7k miles. Did a download when I put the cleaner on and it hasnt seemed to help. Drive 70 mph or less and take my time getting there. I understand your angst - know youre not the only one. Still trying to figure something on how to get the mileage up.
Old 07-27-2011, 09:59 PM
PistonPuller's Avatar
PistonPuller
PistonPuller is offline
What are your AFR tables set at?
Quick Reply: Bad gas mileage
