oil Temp
I understand all touring bikes have coolers now. A Dyna Switchback on the showroom of my local dealer has the 103 but no cooler, so I guess they're limited to the touring class and CVO's.
Synthetic breaks-down slower and can handle more heat, but the problem doesn't go away by using it. A cooler will do a better job of controlling peak oil temps than no cooler at all, and the bigger the temperature swings the more engine tolerances change over the course of normal operation, which doesn't help long-term durability.
I've been running amsoil since my 07 was new, it has 65k and runs 260-280 on a warm day and has hit 300 on a hot day running hard with no concerns, as mentioned the motors are built to withstand the high heat and a good synthetic can withstand the high temps, amsoil is rated for 400+ before the viscosity starts to break down. From what I've heard a cooler will cool the oil from 10-20 degrees and only if you are moving they are worthless in stop and go traffic. IMO a cooler is not necessary; it does give piece of mind to some.
Oil type with temps and 65K on the clock.
And I got shook when mine was stock and hit 255.
If you are running a high lift cam you are also using heavy pressure valve springs. The valve springs are cooled by oil flow alone. If you can keep the temperatures lower on the valve springs they will last longer. There will not be a temperature related failure that you can see. The spring rate will soften, especially at full lift and valve float will set in at high rpm's. That is when your engine will fail and you'll have no idea that it was oil temperature related. Stock engine? No problem. Modify it, cool it. There are a couple of forced air coolers out now, UltraCool and Jagg. If I invested as much money IN my engine as it takes to light these mothers up; I would put that kind of investment ON my engine.
I ran a few hours in 85-90 heat last week. Got home and had the old oil temp oil gauge from my flstf, stuck it on the engine fins and let it rest there a few minutes until it quit at 240 degrees.
I am running castrol 20-50 v twin, and will go to mobil1 20-50 synthetic this week.
I got 1500 miles on the bike and will have 1K service done, and I change he oil at 1K.
I think an oil cool as the RKC comes with with the 103 is a nice feature.
These buggers run hot, and hope dyno tune will take some of that heat down.
Cheers,
Mark
Cheers,
Mark
Based on independent tests I've seen your Amsoil's viscosity starts breaking down at about the same temperature as other high-quality synthetics. Please show evidence for your claim that it doesn't oxidize until 400°. Thanks in advance. Amsoil is a good oil but it isn't a panacea and there are many other good synthetic products on the market.
Coolers work when stationary by convection--not as well as when airflow is present, but there is some cooling effect that occurs. Plus, the temperature starts out lower than it would be otherwise giving you more time to get moving again before the oil gets to a critical temperature.
The point is the oil never reaches a critical temperature even using the HD fossil oil. Any good synthetic oil is good to 400*. I'm not saying an oil cooler is a bad thing I'm very doubtful as to how necessary it is. I do respect your opinion however. I'm going to send off a sample of my oil for analysis next oil change. (5,000 mi) I will try to post the results on the forum.
My position on oil coolers is mostly that they keep oil at a more consistent temperature with smaller swings upward, which IMO is not only better for the engine components but minimizes oxidation of the oil.
My oil temps run 225-260* depending on air temp. At 75 mph it is usually 238-250* when air temps are 98*-103*. That is 2 up and loaded. In the winter it will barely reach 220*. My concern here in Fl is getting the oil hot enough to cook off water condensation and other impurities. Oil that is too cool will create acids that are harmful to all metal parts of an engine. I quit wrenching yrs ago but back then engine parts would be heavily pitted from acids. Haven't had the need to take any late model engines apart and at this point have no idea what one might find. It will probably be another month or two before my bike will need an oil change but will pm you the results. I use 20w50 Amsoil. what is your favorite?
