Bad Tender
Old 07-24-2011, 11:30 PM
Rocc's Avatar
Rocc
Rocc is offline
Stage II
Default Bad Tender
My battery went down and the HD tender I'm using won't charge it. I only get the amber colored flashing lights. Any thoughts?
Old 07-25-2011, 12:33 AM
Potato_Potato's Avatar
Potato_Potato
Potato_Potato is offline
This is from the Tender manual
WORKING WITH A DEAD BATTERY OR A BATTERY WITH A VERY LOW VOLTAGE: If you try to charge a dead battery having a voltage below 3 Volts, the BATTERY TENDER® CHARGERS will not start to charge because an internal safety circuit prevents the battery chargers from generating any DC output voltage.
Old 07-25-2011, 06:30 AM
Jerry1834's Avatar
Jerry1834
Jerry1834 is offline
If you are looking for a new Tender I have one NIB Deltran Plus....$47 shipped....In the F/S section.
What year bike? Did you un-plug it and try again. Maybe the +/- is reversed on your battery...
Old 07-25-2011, 07:00 AM
vtwinbob's Avatar
vtwinbob
vtwinbob is offline
check your charger first, also there's an inline fuse on the charging pig tail going to the battery, i believe it's a 1.5amp it might be bad, see if you can get the battery to charge. make sure all the connections are clean. if all else fails pull it and have it load tested.
Old 07-25-2011, 07:13 AM
HDJIM1158's Avatar
HDJIM1158
HDJIM1158 is offline
For a battery tender to work correctly, you should attach it to the bike FRIST then plug it in..... try this and see. If the battery is shot, the tender will not charge it.
Be Safe JIM
Old 07-25-2011, 09:15 AM
huddle's Avatar
huddle
huddle is offline
A Battery Tender will not charge a dead Battery, it is only used to maintane the battery. First post by Potato-Potato is on the money.
Old 07-25-2011, 09:17 AM
GLACIERPEARL's Avatar
GLACIERPEARL
GLACIERPEARL is offline
The tenders have a very LONG warranty !! How old is yours ?? I believe 5 or 5 years is the warranty.
Also,...........they are sold on EBAY for $27 shipped.
Old 07-25-2011, 09:19 AM
xpilot's Avatar
xpilot
xpilot is offline
Had the same issue this spring. My battery in another bike was dead due to my bro forgetting to turn off the key after messing around. I discovered this 2 months later. I used a small charger that I had for my fish locator to charge the battery for about an hour. I then was able to get the tender to work from there. Worked perfectly!
Old 07-25-2011, 09:22 AM
valvestem's Avatar
valvestem
valvestem is offline
I had an HD Tender go bad on me, it was beyond warranty as well. I went to an auto parts store and bought a Schumacher battery charger for considerably less money. It is in it's 4th year now.
Old 07-25-2011, 09:45 AM
hawg08's Avatar
hawg08
hawg08 is offline
How did you know it was bad? Mine seems to stay warm all the time. Is this normal?
Quick Reply: Bad Tender
