Fix-A-Flat got me home, now what?
Old 07-24-2011, 09:18 PM
hockey8787's Avatar
hockey8787
hockey8787 is offline
You really didnt have to ask this question did you??
Old 07-24-2011, 09:43 PM
cdestuck's Avatar
cdestuck
cdestuck is offline
Veteran: Marine Corp
No question....and if ya dont have the time, spring and have someone do it. Ya dont and every mile your goin to be wondering just when..........................
Old 07-24-2011, 09:57 PM
Turbo3pt3's Avatar
Turbo3pt3
Turbo3pt3 is offline
Is it just me, or am I seeing a trend here in replies. Just orderd a new tire. Old tire only had about a thousand miles on it so it pained me to do it, but.........
Thanks everyone who responded.
Old 07-24-2011, 10:06 PM
j1mmy's Avatar
j1mmy
j1mmy is offline
most likely there is no reason to replace the tire(unless it has low tread or sidewall damage) you do need to clean the fix a flat out,it is only for a temp repair,it will thru off the balance, and can lead to a blow out..find out where the leak was,patch the tire,replace the valve,put in a tube..what ever it needs
Old 07-24-2011, 10:18 PM
Turbo3pt3's Avatar
Turbo3pt3
Uh-Oh. A break in the consensus. Can the tire be reused?
Old 07-24-2011, 10:54 PM
Dionicio's Avatar
Dionicio
Dionicio is offline
No Way!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 07-24-2011, 11:36 PM
Grummpy Bear's Avatar
Grummpy Bear
Grummpy Bear is offline
Originally Posted by barrygreen
I work for a tire retailer also, your tire with fix a flat is now junk. Replace it.
If there is no problem with the tire and it was only the valve stem why not clean up the fix a flat put in a new valve stem and reinstall the tire ???
Why is the tire JUNK, please explain.
Old 07-25-2011, 05:32 AM
geezer glide 56's Avatar
geezer glide 56
geezer glide 56 is offline
Get that stuff out of your wheel as soon as possible fix a flat is very corrosive to aluminum wheels.
Old 07-25-2011, 05:45 AM
smokindave's Avatar
smokindave
smokindave is offline
Was this flat on your tubed RK tire?
Old 07-25-2011, 07:25 AM
geezer glide 56
It is very possible that if the tire was ridden any distance extremely low on air pressure or flat...It will have broken cords in the tire...causing bulges or knots on the tire...But obviously not in this case...I have seen it many times before.
Quick Reply: Fix-A-Flat got me home, now what?
