power commander help
I am getting decel pop. Brought my 07 RK to a indy tech who put bike on dyno for a few minutes. He was unable to duplicate pop on dyno and went ahead and reset 0 throttle from -10 t0 20. I am still getting pop.
Removed pc lll from bike and hooked up to my computer. Don't own a lap top.
What I found was fuel table 1 was brought up to 20 and nothing was changed on fuel table 2.
Is not fuel 2 the front cylinder? and should it be increased?
Any help is appreciated.
From what Keith from FuelMoto told me, yes, both front and rear 0% throttle should be the same, you do have to set both cyls. That being said, from -10 to 20 sounds like a lot of changes (from -10% to +20%!).
Keith told me to try adding 5 at a time. I am running Jackpot dyno pipes w/ quiet baffle, and 10-15 seems to do the trick, still playing with it, though.
I am getting decel pop. Brought my 07 RK to a indy tech who put bike on dyno for a few minutes. He was unable to duplicate pop on dyno and went ahead and reset 0 throttle from -10 t0 20. I am still getting pop. Removed pc lll from bike and hooked up to my computer. Don't own a lap top. What I found was fuel table 1 was brought up to 20 and nothing was changed on fuel table 2. Is not fuel 2 the front cylinder? and should it be increased? Any help is appreciated.
I think Crisis is right and i would follow Keith's recommendation of adding a bit at a time. IMO going 20 is too much and the friends I've helped with this problem were usually happy at 5-10. BTW, I wouldn't change anything below about 3000 rpms. On my original map from Fuel Moto the 0% column was -10% from 3000 and higher, and there was a point (2000-2250) that was too rich and I subtracted fuel in that area. If you smell fuel when you decel, locate that RPM point and subtract fuel there until you don't smell it and have no popping.
